I’m not sure what the issue is but when I run the open loop velocity control example with a single line changed to use the 6 PWM drivers of the B-G431 rather than the default 3 PWM I get insane current draw and the motor doesn’t spin. This is before I have sent any commands. I’ve tried with a few different motors and I’m not sure what the cause is but it is consistent. I ran the example script to send specific voltages to the driver pins and those matched expectations. My code is below.
BLDCMotor motor = BLDCMotor(8);
// BLDCDriver3PWM driver = BLDCDriver3PWM(9, 5, 6, 8);
//target variable
float target_velocity = 0;
driver.voltage_limit = 6;
// limiting motor movements
// open loop control config
// init motor hardware
