Hello FOCfriends,
Background to my question:
I’ve built a balancing bot, which generally already works, but I’ve noticed some optimization potential regarding the standstill capabilities.
So I want to start with the inner torque control loop and analyze and optimize its behavior in terms of control theory.
I wanted to check the bandwidth of the current controller, the digital low-pass filter, and maybe optimize the FOC loop time, which gives me the sample time of the system and defines the Nyquist frequency. In the next step I want to check the cutoff frequency of an analog low-pass filter in front of the current-sensing ADCs to avoid anti-aliasing (aliasing could results in folding back high frequencies into the low-frequency area and the controller wants to compensate for something that isn’t present, which could be the problem of my standstill performance).
But my driver board - and also 4 others I’ve checked - doesn’t have any anti-aliasing filters for current measurement.
So my question is, do I miss something regarding ADs and anti-aliasing fitlers, or are there badly designed driver boards on the market? I think the first assumption is true, but how do the boards avoid aliasing?
I’ve also read about sigma-delta ADCs. They work with oversampling and decimation, which results in a possibly simpler anti-aliasing filter.
But also with the sigma delta ADs, they are needed.
Thanks BEdyn
