6PWM problem when driver motor
Hello every one, I have a problem in simplefoc. It is ok when I use 3PWM mode to driver motor, but it is wrong when I use 6PWM. UVW of driver is always 0V. I don’t know why.
// program
#include “SimpleFOC.h”
//BLDCDriver3PWM driver = BLDCDriver3PWM(PA8, PA9, PA10); // good running
BLDCDriver6PWM driver = BLDCDriver6PWM(PA8, PA9, PA10, PA7, PB0, PB1, PA11); // bad running
//BLDCDriver6PWM driver = BLDCDriver6PWM(PA8, PA9, PA10, PB13, PB14, PB15, PA11); // bad running
driver.voltage_limit = 12;
driver.setPwm(3, 1, 5);
platformio.ini
[env:genericSTM32F103CB]
platform = ststm32
board = genericSTM32F103CB
framework = arduino
lib_archive = false
lib_deps = askuric/Simple FOC@^2.3.4
If you use the build flag
SIMPLEFOC_STM32_DEBUG
You will get more details what is going wrong during the initialization.
Thanks for you response! I have know what is wrong. The right code should be follow.
BLDCDriver6PWM driver = BLDCDriver6PWM(PA8, PA7, PA9, PB0, PA10, PB1);
driver.enable();
driver.setPwm(1, 3, 5);
