4PP 42Blf02 needs more than 2x power in reverse and vibrates
Should this setup work with simplefoc?
Because it is only working in one direction.
Does anyone else have such a motor with external Hall sensors?
Is this the problem?
Console output:
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CW
MOT: PP check: OK!
MOT: Zero elec. angle: 1.05
Is it misaligne in reverse?
I found this in this thread: https://community.simplefoc.com/t/current-consumption/1953
Working with these settings now
if(motor.shaft_velocity > 1){
gain= 0.0045; // a gain factor - to try out
delta_angle_max = 1.2;
else if(motor.shaft_velocity < -1){
gain= 0.0025; // a gain factor - to try out
delta_angle_max = 0.5;
float delta_el_angle = _constrain(motor.shaft_velocity*gain, -delta_angle_max ,delta_angle_max );
// set the new angle
motor.zero_electric_angle = zero_angle_toremember- delta_el_angle ;
Looks like you’ve found a hack to improve things… perhaps with the Hall Sensors the alignment isn’t quite finding the zero angle correctly…
