Driver chip selection advice
I had a dream and came up with this
Rcs is optional for external low-side current sense, you will ignore. You will need an amplifier and analog sample MCU pin and low-side current sensing code from FOC. Values for Rcs based on 10A peak current are around 0.1 ohm. The manufacturer will most definitely ignore your email unless you buy from them 1000000 of those.
Yes, 1.4 ohm rdson resistance is high but then this is a 500V device for 20 cents, so compromises must be made.
Ask any other questions.
Yeah, I’m not going to hold my breath, I figured it was a long shot but it’s free :grinning:
Is this in EasyEDA? Any chance I can copy and paste it?
Yes, it takes about 10 minutes.
No, that’s a homework. If you get stuck, please ask.
Fair enough, I thought you might have some good capacitor selections that I could mooch off :grinning:
For EasyEDA / LCSC look for “basic” parts please.
I threw together a quick and dirty test board and ordered them so we should have some results next week :grinning:
Let’s do that! Leeroy… Jeeeenkins…
The good news is that the boards are here!
The bad news is that they don’t seem to do much of anything :stuck_out_tongue:
I’m running in 6 pwm mode and seeing good clean pwm signals on the input pins (H_1_A and L_1_A for example), but I’m not seeing any voltage on the motor side of the drivers.
I did find a couple of other issues. The zener diode which was supposed to turn on the 3.3 volt regulator didn’t work so I replaced that with a resistive voltage divider which seems to be working well.
I also noticed that datasheet for the driver board actually calls for 15V for VCCB instead of 12 volts so I soldered in an external power supply to get the right voltage there, but that didn’t have an impact.
I’m not quite sure what to try next. It seems like the operating conditions for the chip are being met at least as far as I can tell from the somewhat limited datasheet.
Here’s my whole schematic:
Any thoughts on where to look next?
Hard to tell without any pictures and PCB layout.
Yeah, that’s true. I made the easyEDA project public here: EasyEDA(Standard) - A Simple and Powerful Electronic Circuit Design Tool
Here’s how I have the board set up. The modifications are to use a resistor divider instead of the zener diode to turn on the 3.3 volt regulator, and replacing the 12v regulator with an external power supply to see if the voltage there was limiting the board from coming on.
I don’t know how useful this would be, but here is what the layout looks like:
Thanks, this is helpful.
PS1. I don’t see obvious problems. @BarbourSmith , are you in one of the lower 49 states?
On the one hand I’m stoked that there isn’t an obvious issue for the sake of my ego, on the other hand it would be great if I did something silly that was easy to fix :stuck_out_tongue:
I’m in Seattle, I’ve got a second un-modified board here that I’m happy to send to you if you want to poke at it in person.
I messaged you, please check your messages.
