Check out MCP2562FD
They do recommend a choke for higher through-put.
Do any of you have experience with common mode chokes. As far as i gather, one needs to be careful with emf/ringing. I have a keep out area below the choke, but only on top layer just below the choke. Because of space restrictions I need a copper (gnd) layer/shield between the choke and the CAN FD IC on the flip side?
The windings on the choke is raised a bit from the board though…
