I have a arduino uno and simplefoc shield v2.0.4. But I have no idea what to burn to the arduino.
I have tried the code below but exceeded the size of flash memory:
// driver
// encoder instance
MagneticSensorSPI encoder = MagneticSensorSPI(AS5048_SPI, 10);
// current sense
InlineCurrentSense current_sense = InlineCurrentSense(0.01f, 50.0f, A0, A2);
// include commander interface
void setup(){
// SimpleFOCDebug::enable(&Serial);
encoder.init();
motor.linkSensor(&encoder);
current_sense.init();
command.add('M',doMotor,'motor');
// tell the motor to use the monitoring
motor.monitor_downsample = 0; // disable monitor at first - optional
void loop(){
// real-time monitoring calls
// real-time commander calls
