Hi, the new version of the site is awesome, but I’m facing a problem with plotting on the simple foc web. The graphs just don’t show up, no matter what settings I try to set (as in the screenshot)
The data is visible when viewed in VS Code serial monitor. Also, if you click on Clear Output in SimpleFocWeb, the data will be displayed as well (as in the screenshot).
Here is my code:
#include "encoders/MT6701/MagneticSensorMT6701SSI.h"
BLDCMotor motor = BLDCMotor(7, 0.19, 300, 0.00004, 0.00003);
BLDCDriver3PWM driver = BLDCDriver3PWM(16, 17, 5, 4);
#define SENSOR1_CS 13
MagneticSensorMT6701SSI sensor(SENSOR1_CS);
InlineCurrentSense current_sense = InlineCurrentSense(0.005, 50.0, 39, 36, _NC);
driver.voltage_power_supply = 22;
motor.voltage_sensor_align = 0.7;
motor.voltage_limit = 2;
sensor.min_elapsed_time = 0.001;
if(!driver.init()){
return;
if(!current_sense.init()){
Serial.println("Current sense init failed!");
return;
driver.pwm_frequency = 20000;
motor.torque_controller = TorqueControlType::estimated_current;
// velocity loop PID
motor.PID_velocity.P = 0.8;
motor.PID_velocity.I = 5;
motor.PID_velocity.D = 0.002;
motor.PID_velocity.output_ramp = 1000.0;
motor.LPF_velocity.Tf = 0.07;
// angle loop PID
motor.P_angle.P = 6.5;
motor.P_angle.I = 0.0;
motor.P_angle.D = 0.0;
motor.P_angle.output_ramp = 0;
motor.LPF_angle.Tf = 0.1;
// current q loop PID
motor.PID_current_q.P = 0.01955;
motor.PID_current_q.I = 57.41975;
motor.PID_current_q.D = 0.0;
motor.PID_current_q.output_ramp = 0.0;
motor.PID_current_q.limit = 4;
motor.LPF_current_q.Tf = 0.00053;
// current d loop PID
motor.PID_current_d.P = 0.01288;
motor.PID_current_d.I = 57.41975;
motor.PID_current_d.D = 0.0;
motor.PID_current_d.output_ramp = 0.0;
motor.PID_current_d.limit = 4;
motor.LPF_current_d.Tf = 0.00053;
// Limits
motor.velocity_limit = 75.0;
motor.voltage_limit = 3;
motor.current_limit = 5;
if(!motor.init()){
return;
if(!motor.initFOC()){
Serial.println("FOC init failed!");
return;
motor.target = 0; // one rotation per second
//display variables
motor.monitor_variables = _MON_TARGET | _MON_VEL | _MON_ANGLE;
// downsampling
motor.monitor_downsample = 100; // default 10
command.add('M', doMotor, "Motor");
// motor monitoring
