The code running on esp32 does not work on stmf401
I decided to try the work of the stm and used the code that I used on the esp32 board. Renamed the connection pins. But instead of rotating, I got a hold position
   * ESP32 position motion control example with encoder
  int S;
  // Motor instance
  BLDCDriver3PWM driver = BLDCDriver3PWM(PB6, PB7, PB8, PB5);
  // encoder instance
  Encoder encoder = Encoder(PA8, PA9, 600, PA10);
  // channel A and B callbacks
  void doI(){encoder.handleIndex();}
  // angle set point variable
  float target_angle = 0;
    encoder.init();
    encoder.enableInterrupts(doA, doB, doI);
    motor.linkSensor(&encoder);
    //driver.enable_active_high = false;
    // aligning voltage [V]
    // contoller configuration
    motor.PID_velocity.P = 0.2f;
    motor.PID_velocity.I = 0;
    motor.voltage_limit = 6;
    // angle P controller
    motor.P_angle.P = 100;
    motor.velocity_limit = 100;
  float almost_zero_velocity = 1; // rad/s
    if(motor.shaft_velocity > almost_zero_velocity){motor.zero_electric_angle = 1.97;}
  else if(motor.shaft_velocity < -almost_zero_velocity){motor.zero_electric_angle =3.16 ;}
  else{ motor.zero_electric_angle = 2.56;}
  S=map(analogRead(PA11), 1895, 0, 0, -42);
    // Arduino UNO loop  ~1kHz
    // Bluepill loop ~10kHz
    motor.move(S);
    // motor.monitor();
Hmmmm, not sure what’s going on there. Your code looks ok at first glance.
Is this on PlatformIO or ArduinoIDE?
Which pins is your serial port using? Do you see the serial output from the F401?
Which F401 board are you using? Is it a BlackPill type board or a Nucleo?
the black pill board, reading the analog input from pin 11 does not occur. I changed to pin 7 and it reads from 0 to 1023. I don’t know why it should be up to 4096. stm32f401cc
PA11 is not an analog pin. You can find that in the variant file from the stm32core.
I think they set analog read to 10 bit for compatibility with arduino
analogReadResolution(12); //in void setup()
will get your wanted result.
I have seen a picture from your steering wheel in another thread. I would like one too. Where are the commands for the motor coming from?
Good afternoon. Thank you, it really helped. The signal source is the stm32f407 on which the VNM firmware is installed. It’s better to have it all on one controller, but I’m new to programming
