I cannot use the angle LPF with my setup (SimpleFOCShield v2). Any non-zero value in motor.LPF_angle.Tf
causes strange behaviors.
Here is the most simple example I could isolate (I’ve got other cases, with other modes):
This code sets target=3V in torque+voltage mode:
SPIClass SPI_3(PC12, PC11, PC10);
MagneticSensorSPI sensor(PD2, 14, 0x3FFF);
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50.0, A0, A2);
void doMotor(char* cmd){ command.motor(&motor, cmd); }
sensor.init(&SPI_3);
driver.voltage_power_supply = 14.5;
// HERE WE ARE:
// motor.LPF_angle.Tf = 0.005;
motor.monitor_downsample = 0;
motor.monitor_variables = 0xFF;
current_sense.init();
motor.target = 3;
Here is what I get when the HERE WE ARE line is commented out (nice low current and high speed):
Here is what I get when the HERE WE ARE line is uncommented (high current and low speed):
Anyone understands what’s happening here?
