I’ve recently started to use the SimpleFOClibrary but I’m running into some issues when trying to control a Nema 17 with a AS5600 and L298N off of a Nucleo-64. I’m primarily following the example stepper drive code from the examples, but when the motor is turning it sounds just like a bad stepper driver with rough steps and uneven velocity over each rotation. Additionally, it has significant cogging when backdriven. I’m suspecting that there is a lot of performance I’m leaving on the table as a result of my code. The physical wiring of the project is the same as the stepper example except for the AS5600, which I have separately verified to be working. The serial monitor output indicates that the motor gets successfully initiated and returns a magnetic angle and the “Ready” message. Does it look like I’m missing anything in my code that could be causing me these problems? Thank you for the assistance, I’m really excited to have this working!
// Stepper motor instance
// Stepper driver instance
StepperDriver4PWM driver = StepperDriver4PWM(5, 6, 9, 10);
// instance of AS5600 sensor
MagneticSensorI2C encoder = MagneticSensorI2C(AS5600_I2C);
// commander interface
// set voltage for initial config
encoder.init();
//encoder.enableInterrupts(doA, doB);
motor.linkSensor(&encoder);
// choose FOC modulation
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.voltage_limit = 12;
motor.LPF_velocity.Tf = 0.01;
// angle loop controller
motor.P_angle.P = 20;
// angle loop velocity limit
motor.velocity_limit = 50;
// monitoring port
// initialise motor
motor.target = 1;
// define the motor id
