Steer by wire Example
I am really close, but only one side controls the other, and not vice versa.
Trying to recreate https://docs.simplefoc.com/haptics_examples
https://www.instagram.com/p/Cc-CvAcgl-v/
I am using 2 magnetic encoders with an I2C multiplexer
What do I need to do to make it work correctly?
I read about I2C multiplexer, and I think that could be a problem. Both motors works ok? You tried simple rotation?
I had to call out the encoder address every-time the corresponding motor is called
I still don’t know if this is actually correct because it still takes too much force to move without load
https://www.instagram.com/p/Cc-5-RpgbUW/
