I’ve been looking for a while on how to get the SPI to work on RP2040 so I’m sharing.
#include "Arduino.h"
#include "Wire.h"
#include "SPI.h"
#include "SimpleFOC.h"
#include "SimpleFOCDrivers.h"
#include "encoders/as5048a/MagneticSensorAS5048A.h"
#define CS_ENC 1 // some digital pin that you're using as the nCS pin
MagneticSensorAS5048A sensor1(CS_ENC);
// https://github.com/earlephilhower/arduino-pico/blob/master/libraries/SPI/src/SPI.cpp
// https://arduino-pico.readthedocs.io/en/latest/pins.html
// https://arduino-pico.readthedocs.io/en/latest/spi.html
SPI.setRX(0); // MISO
SPI.setTX(3); // MOSI
SPI.setSCK(2); // SCK
SPI.setCS(1); // CS Chip Select
sensor1.init();
// update the sensor (only needed if using the sensor without a motor)
sensor1.update();
// get the angle, in radians, including full rotations
float a1 = sensor1.getAngle();
Serial.println(a1);
// get the velocity, in rad/s - note: you have to call getAngle() on a
// regular basis for it to work
float v1 = sensor1.getVelocity();
// get the angle, in radians, no full rotations
float a2 = sensor1.getCurrentAngle();
// Serial.println(a2);
// get the raw 14 bit value
uint16_t raw = sensor1.readRawAngle();
// read the CORDIC magnitude value, a measure of the magnet field strength
float m1 = sensor1.readMagnitude();
// check for errors
if (sensor1.isErrorFlag()) {
AS5048Error error = sensor1.clearErrorFlag();
if (error.parityError) { // also error.framingError, error.commandInvalid
// etc...
