Something went horribly wrong with my SimpleFOCShield
My SimpleFOCShield is configured like this: BLDCDriver3PWM(9, 5, 6, 8).
Yesterday, I tried to change the SPI pins of my magnetic sensor. Instead of pins 10,11,12,13, I plugged it on pins 2,3,4,5 and used the following code:
MagneticSensorAS5048A sensor(2);
SPI.setSCLK(PB_3);
SPI.setMISO(PB_4);
SPI.setMOSI(PB_5);
The sensor did work, but the motor didn’t, probably because I forgot pin 5 was supposed to be phB!
I’ve put everything back in place, but my SimpleFOCShield doesn’t seem to work anymore. No voltage seems to ever be applied to the motor, whatever the (previously working) app I use:
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Init FOC failed.
Does it make sense to you? Did I permanently break something?
Did you modified your cabling? i happened to me many times that while modifying pin assignments some cable gets unintenrionally loose.
