SimpleFOC stm32 reaction wheel
Hi all,
I’m doing a project with a reaction wheel inverted pendulum using a STM32 microcontroller. But the pendulum won’t swing. The motor only turns in one direction and stops in a loop. Please kindly suggest on what I can do. Thank you.
My current setup is
  • STM32-L476RG
  • SimpleFOCShield v2.0.4
  • iPower GM6208 Gimbal Motor
  • 2x AMT103 (set to 2048 PPR)
  • 12V Power Supply (both voltage and current can be adjusted)
I have adjusted the pins to accomodate the STM32 board.
// BLDC motor init
// define BLDC driver
BLDCDriver3PWM driver = BLDCDriver3PWM(PA8, PA9, PA10, PC7);
//Motor encoder init
Encoder encoder = Encoder(PB4, PB5, 2048);
// interrupt routine
// pendulum encoder init
Encoder pendulum = Encoder(PB6, PB7, 2048);
void doPA(){pendulum.handleA();}
void doPB(){pendulum.handleB();}
  // initialize motor encoder hardware
  encoder.init();
  encoder.enableInterrupts(doA,doB);
  // init the pendulum encoder
  pendulum.init();
pendulum.enableInterrupts(doPA,doPB);
  // link the motor to the encoder
  motor.linkSensor(&encoder);
  // link the motor to the driver
// loop down-sampling counter
long loop_count = 0;
  // ~1ms
  // pendulum sensor read
  pendulum.update();
  // control loop each ~25ms
  if(loop_count++ > 25){
    // calculate the pendulum angle
    float pendulum_angle = constrainAngle(pendulum.getAngle() + _PI);
    float target_voltage;
    if( abs(pendulum_angle) < 0.5 ) // if angle small enough stabilize
      target_voltage = controllerLQR(pendulum_angle, pendulum.getVelocity(), motor.shaft_velocity);
    else // else do swing-up
      // sets 40% of the maximal voltage to the motor in order to swing up
      target_voltage = -_sign(pendulum.getVelocity())*driver.voltage_power_supply*0.4;
    // set the target voltage to the motor
    motor.move(target_voltage);
    // restart the counter
    loop_count=0;
// function constraining the angle in between -pi and pi, in degrees -180 and 180
float constrainAngle(float x){
    x = fmod(x + _PI, _2PI);
    if (x < 0)
        x += _2PI;
    return x - _PI;
// LQR stabilization controller functions
// calculating the voltage that needs to be set to the motor in order to stabilize the pendulum
float controllerLQR(float p_angle, float p_vel, float m_vel){
  // if angle controllable
  // calculate the control law
  // LQR controller u = k*x
  //  - k = [40, 7, 0.3]
  //  - x = [pendulum angle, pendulum velocity, motor velocity]'
  float u =  40*p_angle + 7*p_vel + 0.3*m_vel;
  // limit the voltage set to the motor
  if(abs(u) > driver.voltage_power_supply*0.7) u = sign(u)*driver.voltage_power_supply*0.7;
  return u;
video of setup running the Reaction Wheel example code
