_SAME51_ pin configuration
@runger
The SAMD51/SAME51 pin configuration is nonsensical to me. I have the 3 pwm pins (digital pins 13(PA23), 12(PA22), 10(PA20)) on TCC channel 0, but the core keeps putting pin 10 on TC12 and D13/D12 on TCC1.
The library seem to favorize TCC channe1 ?
[Edit] : It would be so much cooler, if one could specify the pin TCC channel and number. How du you score the combinations. If you use 3pwm motion control and want all the pins on the same TCC, the library does not allow for this.
Here is my terminal/DEBUG readout:
#include "./samd_mcu.h"
#if defined(_SAMD51_)||defined(_SAME51_)
//	TCC#   Channels   WO_NUM   Counter size   Fault   Dithering   Output matrix   DTI   SWAP   Pattern generation
//	0         6         8         24-bit       Yes       Yes       Yes            Yes   Yes    Yes
//	1         4         8         24-bit       Yes       Yes       Yes            Yes   Yes    Yes
//	2         3         3         16-bit       Yes       -         Yes            -     -      -
//	3         2         2         16-bit       Yes       -         -              -     -      -
//	4         2         2         16-bit       Yes       -         -              -     -      -
#define NUM_WO_ASSOCIATIONS 72
struct wo_association WO_associations[] = {
		{ PORTB,   9, TC4_CH1, 		1, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0},
		{ PORTA,   4, TC0_CH0, 		0, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0},
		{ PORTA,   5, TC0_CH1, 		1, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0},
		{ PORTA,   6, TC1_CH0, 		0, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0},
		{ PORTA,   7, TC1_CH1, 		1, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0},
		{ PORTC,   4, NOT_ON_TIMER, 0, TCC0_CH0, 	    0, NOT_ON_TIMER, 	0},
		// PC05, PC06, PC07 -> no timers
		{ PORTA,   8, TC0_CH0, 		0, TCC0_CH0,     	0, TCC1_CH0, 		4},
		{ PORTA,   9, TC0_CH1, 		1, TCC0_CH1,     	1, TCC1_CH1, 		5},
		{ PORTA,  10, TC1_CH0, 		0, TCC0_CH2,     	2, TCC1_CH2, 		6},
		{ PORTA,  11, TC1_CH1, 		1, TCC0_CH3,     	3, TCC1_CH3, 		7},
		{ PORTB,  10, TC5_CH0, 		0, TCC0_CH0, 		4, TCC1_CH0, 		0}, //?
		{ PORTB,  11, TC5_CH1, 		1, TCC0_CH1,  		5, TCC1_CH1, 		1}, //?
		{ PORTB,  12, TC4_CH0, 		0, TCC3_CH0, 		0, TCC0_CH0, 		0},
		{ PORTB,  13, TC4_CH1, 		1, TCC3_CH1, 		1, TCC0_CH1, 		1},
		{ PORTB,  14, TC5_CH0, 		0, TCC4_CH0, 		0, TCC0_CH2, 		2},
		{ PORTB,  15, TC5_CH1, 		1, TCC4_CH1, 		1, TCC0_CH3, 		3},
		{ PORTD,   8, NOT_ON_TIMER,	0, TCC0_CH1,     	1, NOT_ON_TIMER, 	0},
		{ PORTD,   9, NOT_ON_TIMER,	0, TCC0_CH2,     	2, NOT_ON_TIMER, 	0},
		{ PORTD,  10, NOT_ON_TIMER,	0, TCC0_CH3,     	3, NOT_ON_TIMER, 	0},
		{ PORTD,  11, NOT_ON_TIMER,	0, TCC0_CH0, 		4, NOT_ON_TIMER, 	0}, //?
		{ PORTD,  12, NOT_ON_TIMER,	0, TCC0_CH1,  		5, NOT_ON_TIMER, 	0}, //?
		{ PORTC,  10, NOT_ON_TIMER,	0, TCC0_CH0,     	0, TCC1_CH0, 		4},
		{ PORTC,  11, NOT_ON_TIMER,	0, TCC0_CH1,     	1, TCC1_CH1, 		5},
		{ PORTC,  12, NOT_ON_TIMER,	0, TCC0_CH2, 		2, TCC1_CH2, 		6},
		{ PORTC,  13, NOT_ON_TIMER,	0, TCC0_CH3, 		3, TCC1_CH3, 		7},
		{ PORTC,  14, NOT_ON_TIMER,	0, TCC0_CH0, 		4, TCC1_CH0, 		0}, //?
		{ PORTC,  15, NOT_ON_TIMER,	0, TCC0_CH1, 		5, TCC1_CH1, 		1}, //?
		{ PORTA,  12, TC2_CH0,		0, TCC0_CH2, 		6, TCC1_CH2, 		2},
		{ PORTA,  13, TC2_CH1,		1, TCC0_CH3, 		7, TCC1_CH3, 		3},
		{ PORTA,  14, TC3_CH0,		0, TCC2_CH0, 		0, TCC1_CH2, 		2}, //?
		{ PORTA,  15, TC3_CH1,		1, TCC1_CH1, 		1, TCC1_CH3, 		3}, //?
		{ PORTA,  16, TC2_CH0,		0, TCC1_CH0, 		0, TCC0_CH0, 		4},
		{ PORTA,  17, TC2_CH1,		1, TCC1_CH1, 		1, TCC0_CH1, 		5},
		{ PORTA,  18, TC3_CH0,		0, TCC1_CH2, 		2, TCC0_CH2, 		6},
		{ PORTA,  19, TC3_CH1,		1, TCC1_CH3, 		3, TCC0_CH3, 		7},
		{ PORTC,  16, NOT_ON_TIMER,	0, TCC0_CH0, 		0, NOT_ON_TIMER, 	0}, // PDEC0
		{ PORTC,  17, NOT_ON_TIMER,	0, TCC0_CH1, 		1, NOT_ON_TIMER, 	0}, // PDEC1
		{ PORTC,  18, NOT_ON_TIMER,	0, TCC0_CH2, 		2, NOT_ON_TIMER, 	0}, // PDEC2
		{ PORTC,  19, NOT_ON_TIMER,	0, TCC0_CH3, 		3, NOT_ON_TIMER, 	0},
		{ PORTC,  20, NOT_ON_TIMER,	0, TCC0_CH0, 		4, NOT_ON_TIMER, 	0},
		{ PORTC,  21, NOT_ON_TIMER,	0, TCC0_CH1, 		5, NOT_ON_TIMER, 	0},
		{ PORTC,  22, NOT_ON_TIMER,	0, TCC0_CH2, 		6, NOT_ON_TIMER, 	0},
		{ PORTC,  23, NOT_ON_TIMER,	0, TCC0_CH3, 		7, NOT_ON_TIMER, 	0},
		{ PORTD,  20, NOT_ON_TIMER,	0, TCC1_CH0, 		0, NOT_ON_TIMER, 	0},
		{ PORTD,  21, NOT_ON_TIMER,	0, TCC1_CH1, 		1, NOT_ON_TIMER, 	0},
		{ PORTB,  16, TC6_CH0,		0, TCC3_CH0, 		0, TCC0_CH0, 		4},
		{ PORTB,  17, TC6_CH1,		1, TCC3_CH1, 		1, TCC0_CH1,	 	5},
		{ PORTB,  18, NOT_ON_TIMER,	0, TCC1_CH0, 		0, NOT_ON_TIMER, 	0}, // PDEC0
		{ PORTB,  19, NOT_ON_TIMER,	0, TCC1_CH1, 		1, NOT_ON_TIMER, 	0}, // PDEC1
		{ PORTB,  20, NOT_ON_TIMER,	0, TCC1_CH2, 		2, NOT_ON_TIMER, 	0}, // PDEC2
		{ PORTB,  21, NOT_ON_TIMER,	0, TCC1_CH3, 		3, NOT_ON_TIMER, 	0},
		{ PORTA,  20, TC7_CH0,		0, TCC1_CH0, 		4, TCC0_CH0, 		0},
		{ PORTA,  21, TC7_CH1,		1, TCC1_CH1, 		5, TCC0_CH1, 		1},
		{ PORTA,  22, TC4_CH0,		0, TCC1_CH2, 		6, TCC0_CH2, 		2},
		{ PORTA,  23, TC4_CH1,		1, TCC1_CH3, 		7, TCC0_CH3, 		3},
		{ PORTA,  24, TC5_CH0,		0, TCC2_CH2, 		2, NOT_ON_TIMER, 	0}, // PDEC0
		{ PORTA,  25, TC5_CH1,		1, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0}, // PDEC1
		{ PORTB,  22, TC7_CH0,		0, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0}, // PDEC2
		{ PORTB,  23, TC7_CH1,		1, NOT_ON_TIMER, 	0, NOT_ON_TIMER,	0}, // PDEC0
		{ PORTB,  24, NOT_ON_TIMER,	0, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0}, // PDEC1
		{ PORTB,  25, NOT_ON_TIMER,	0, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0}, // PDEC2
		{ PORTB,  26, NOT_ON_TIMER,	0, TCC1_CH2, 		2, NOT_ON_TIMER, 	0},
		{ PORTB,  27, NOT_ON_TIMER,	0, TCC1_CH3, 		3, NOT_ON_TIMER, 	0},
		{ PORTB,  28, NOT_ON_TIMER,	0, TCC1_CH0, 		4, NOT_ON_TIMER, 	0},
		{ PORTB,  29, NOT_ON_TIMER,	1, TCC1_CH1, 		5, NOT_ON_TIMER,	0},
		// PC24-PC28, PA27, RESET -> no TC/TCC peripherals
		{ PORTA,  30, TC6_CH0,		0, TCC2_CH0, 		0, NOT_ON_TIMER, 	0},
		{ PORTA,  31, TC6_CH1,		1, TCC2_CH1, 		1, NOT_ON_TIMER, 	0},
		{ PORTB,  30, TC0_CH0,		0, TCC4_CH0, 		0, TCC0_CH2, 		6},
		{ PORTB,  31, TC0_CH1,		1, TCC4_CH1, 		1, TCC0_CH3, 		7},
		// PC30, PC31 -> no TC/TCC peripherals
		{ PORTB,   0, TC7_CH0,		0, NOT_ON_TIMER, 	0, NOT_ON_TIMER, 	0},
		{ PORTB,   1, TC7_CH1,		1, NOT_ON_TIMER, 	0, NOT_ON_TIMER,	0},
		{ PORTB,   2, TC6_CH0,		0, TCC2_CH2, 		2, NOT_ON_TIMER,	0},
wo_association ASSOCIATION_NOT_FOUND = { NOT_A_PORT, 0, NOT_ON_TIMER, 0, NOT_ON_TIMER, 0, NOT_ON_TIMER, 0};
uint8_t TCC_CHANNEL_COUNT[] = { TCC0_CC_NUM, TCC1_CC_NUM, TCC2_CC_NUM, TCC3_CC_NUM, TCC4_CC_NUM };
struct wo_association& getWOAssociation(EPortType port, uint32_t pin) {
	for (int i=0;i<NUM_WO_ASSOCIATIONS;i++) {
		if (WO_associations[i].port==port && WO_associations[i].pin==pin)
			return WO_associations[i];
	return ASSOCIATION_NOT_FOUND;
EPioType getPeripheralOfPermutation(int permutation, int pin_position) {
	return ((permutation>>pin_position)&0x01)==0x1?PIO_TIMER_ALT:PIO_TIMER;
void syncTCC(Tcc* TCCx) {
	while (TCCx->SYNCBUSY.reg & TCC_SYNCBUSY_MASK);
void writeSAMDDutyCycle(int chaninfo, float dc) {
	uint8_t tccn = GetTCNumber(chaninfo);
	uint8_t chan = GetTCChannelNumber(chaninfo);
	if (tccn<TCC_INST_NUM) {
		Tcc* tcc = (Tcc*)GetTC(chaninfo);
		// set via CCBUF
		while ( (tcc->SYNCBUSY.vec.CC & (0x1<<chan)) > 0 );
		tcc->CCBUF[chan].reg = (uint32_t)((SIMPLEFOC_SAMD_PWM_RESOLUTION-1) * dc); // TODO pwm frequency!
//		tcc->STATUS.vec.CCBUFV |= (0x1<<chan);
//		while ( tcc->SYNCBUSY.bit.STATUS > 0 );
//		tcc->CTRLBSET.reg |= TCC_CTRLBSET_CMD(TCC_CTRLBSET_CMD_UPDATE_Val);
//		while ( tcc->SYNCBUSY.bit.CTRLB > 0 );
	else {
		// Tc* tc = (Tc*)GetTC(chaninfo);
		// //tc->COUNT16.CC[chan].reg = (uint32_t)((SIMPLEFOC_SAMD_PWM_RESOLUTION-1) * dc);
		// tc->COUNT8.CC[chan].reg = (uint8_t)((SIMPLEFOC_SAMD_PWM_TC_RESOLUTION-1) * dc);
		// while ( tc->COUNT8.STATUS.bit.SYNCBUSY == 1 );
#define DPLL_CLOCK_NUM 2  	// use GCLK2
#define PWM_CLOCK_NUM 3  	// use GCLK3
 * Configure Clock 4 - we want all simplefoc PWMs to use the same clock. This ensures that
 * any compatible pin combination can be used without having to worry about configuring different
 * clocks.
void configureSAMDClock() {
	if (!SAMDClockConfigured) {
		SAMDClockConfigured = true;						// mark clock as configured
		for (int i=0;i<TCC_INST_NUM;i++)				// mark all the TCCs as not yet configured
			tccConfigured[i] = false;
		// GCLK->GENCTRL[DPLL_CLOCK_NUM].reg = GCLK_GENCTRL_GENEN | GCLK_GENCTRL_DIV(1)
		// 								  | GCLK_GENCTRL_SRC(GCLK_GENCTRL_SRC_DFLL_Val);
		// while (GCLK->SYNCBUSY.vec.GENCTRL&(0x1<<DPLL_CLOCK_NUM));
		// GCLK->PCHCTRL[1].reg = GCLK_PCHCTRL_GEN(DPLL_CLOCK_NUM)|GCLK_PCHCTRL_CHEN;
		// OSCCTRL->Dpll[0].DPLLCTRLA.bit.ENABLE = 0;
		// while (OSCCTRL->Dpll[0].DPLLSYNCBUSY.reg!=0x0);
		// OSCCTRL->Dpll[0].DPLLCTRLB.bit.REFCLK = OSCCTRL_DPLLCTRLB_REFCLK_GCLK_Val;
		// OSCCTRL->Dpll[0].DPLLRATIO.reg = 3;
		// OSCCTRL->Dpll[0].DPLLCTRLA.bit.ENABLE = 1;
		GCLK->GENCTRL[PWM_CLOCK_NUM].bit.GENEN = 0;
		while (GCLK->SYNCBUSY.vec.GENCTRL&(0x1<<PWM_CLOCK_NUM));
		GCLK->GENCTRL[PWM_CLOCK_NUM].reg = GCLK_GENCTRL_GENEN | GCLK_GENCTRL_DIV(1) | GCLK_GENCTRL_IDC
	 	 	 	 	 	 	 	 	 	 //| GCLK_GENCTRL_SRC(GCLK_GENCTRL_SRC_DPLL0_Val);
#ifdef SIMPLEFOC_SAMD_DEBUG
		Serial.println("Configured clock...");
#endif
 * Configure a TCC unit
 * pwm_frequency is fixed at 24kHz for now. We could go slower, but going
 * faster won't be possible without sacrificing resolution.
void configureTCC(tccConfiguration& tccConfig, long pwm_frequency, bool negate, float hw6pwm) {
	// TODO for the moment we ignore the frequency...
	if (!tccConfigured[tccConfig.tcc.tccn]) {
		uint32_t GCLK_CLKCTRL_ID_ofthistcc = GCLK_CLKCTRL_IDs[tccConfig.tcc.tccn];
		GCLK->PCHCTRL[GCLK_CLKCTRL_ID_ofthistcc].reg = GCLK_PCHCTRL_GEN(PWM_CLOCK_NUM)|GCLK_PCHCTRL_CHEN;
	if (tccConfig.tcc.tccn<TCC_INST_NUM) {
		Tcc* tcc = (Tcc*)GetTC(tccConfig.tcc.chaninfo);
		tcc->CTRLA.bit.ENABLE = 0; //switch off tcc
		while ( tcc->SYNCBUSY.bit.ENABLE == 1 ); // wait for sync
		uint8_t invenMask = ~(1<<tccConfig.tcc.chan);	// negate (invert) the signal if needed
		uint8_t invenVal = negate?(1<<tccConfig.tcc.chan):0;
		tcc->DRVCTRL.vec.INVEN = (tcc->DRVCTRL.vec.INVEN&invenMask)|invenVal;
		syncTCC(tcc); // wait for sync
		if (hw6pwm>0.0) {
			tcc->WEXCTRL.vec.DTIEN |= (1<<tccConfig.tcc.chan);
			tcc->WEXCTRL.bit.DTLS = hw6pwm*(SIMPLEFOC_SAMD_PWM_RESOLUTION-1);
			tcc->WEXCTRL.bit.DTHS = hw6pwm*(SIMPLEFOC_SAMD_PWM_RESOLUTION-1);
			tcc->WAVE.reg |= TCC_WAVE_POL(0xF)|TCC_WAVE_WAVEGEN_DSTOP;   // Set wave form configuration - TODO check this... why set like this?
			while ( tcc->SYNCBUSY.bit.WAVE == 1 ); // wait for sync
			tcc->PER.reg = SIMPLEFOC_SAMD_PWM_RESOLUTION - 1;                 // Set counter Top using the PER register
			while ( tcc->SYNCBUSY.bit.PER == 1 ); // wait for sync
			// set all channels to 0%
			for (int i=0;i<TCC_CHANNEL_COUNT[tccConfig.tcc.tccn];i++) {
				tcc->CC[i].reg = 0;					// start off at 0% duty cycle
				uint32_t chanbit = 0x1<<(TCC_SYNCBUSY_CC0_Pos+i);
				while ( (tcc->SYNCBUSY.reg & chanbit) > 0 );
		// Enable TCC
		tcc->CTRLA.reg |= TCC_CTRLA_ENABLE | TCC_CTRLA_PRESCALER_DIV1; //48Mhz/1=48Mhz/2(up/down)=24MHz/1024=24KHz
		Serial.print("(Re-)Initialized TCC ");
		Serial.print(tccConfig.tcc.tccn);
		Serial.print("-");
		Serial.print(tccConfig.tcc.chan);
		Serial.print("[");
		Serial.print(tccConfig.wo);
		Serial.println("]");
#endif
	else if (tccConfig.tcc.tccn>=TCC_INST_NUM) {
		Tc* tc = (Tc*)GetTC(tccConfig.tcc.chaninfo);
		// disable
		// tc->COUNT8.CTRLA.bit.ENABLE = 0;
		// // unfortunately we need the 8-bit counter mode to use the PER register...
		// tc->COUNT8.CTRLA.reg |= TC_CTRLA_MODE_COUNT8 | TC_CTRLA_WAVEGEN_NPWM ;
		// // meaning prescaler of 8, since TC-Unit has no up/down mode, and has resolution of 250 rather than 1000...
		// tc->COUNT8.CTRLA.bit.PRESCALER = TC_CTRLA_PRESCALER_DIV8_Val ;
		// // period is 250, period cannot be higher than 256!
		// tc->COUNT8.PER.reg = SIMPLEFOC_SAMD_PWM_TC_RESOLUTION-1;
		// // initial duty cycle is 0
		// tc->COUNT8.CC[tccConfig.tcc.chan].reg = 0;
		// // enable
		// tc->COUNT8.CTRLA.bit.ENABLE = 1;
		Serial.print("Initialized TC ");
		Serial.println(tccConfig.tcc.tccn);
	#endif
	// set as configured
	tccConfigured[tccConfig.tcc.tccn] = true;
#endif
oK, Changing this struct makes the lib find the TCC0 first apparently.
struct wo_association {
	EPortType port;
	uint32_t pin;
	ETCChannel tccG;
	uint8_t woG;
	ETCChannel tccE;
	uint8_t woE;
	ETCChannel tccF;
	uint8_t woF;
#endif
readout2
[Edit] This is using pin 13, 12, 11.
Also changed these lines:
{ PORTA,  20, TC7_CH0,		0, TCC0_CH0, 		0, TCC0_CH0, 		0},
		{ PORTA,  21, TC7_CH1,		1, TCC0_CH1, 		1, TCC0_CH1, 		1},
		{ PORTA,  22, TC4_CH0,		0, TCC0_CH2, 		2, TCC0_CH2, 		2},
		{ PORTA,  23, TC4_CH1,		1, TCC0_CH3, 		3, TCC0_CH3, 		3},
Hey @Juan-Antonio_Soren_E ,
Lets keep the conversation on this in the GitHub issue you made for it:
Thanks a lot for reporting it!
WOW
Just went from 301 loops per sec. to 3005 by lowering the resolution.
Changing PWM clock to 100Mhz
Resolution set to 1000
res at 1000
Which resolution are you referring to here? I’m a bit confused by these last messages…
I had it set very high at first.
#ifndef SIMPLEFOC_SAMD_PWM_RESOLUTION
#define SIMPLEFOC_SAMD_PWM_RESOLUTION 1000
#define SIMPLEFOC_SAMD_PWM_TC_RESOLUTION 250
#endif
Is there a reason to use = tcc->WAVE.reg |= TCC_WAVE_POL(0xF)|TCC_WAVE_WAVEGEN_DSTOP; // Set wave form configuration ?
Overclocking to 200Mhz system clock and using GCLK_GENCTRL_SRC_DPLL0; (sys clock for pwm=
I believe this is where the bridges on_resistance, and rise/fall time come into play…
[Edit] maybe be its better to use a lower pwm freq and have more system clock headroom for calculations and stuff.
The ADC sample time is going to have a large effect on void(loop);
There should be a way to use DMA transfers for the Analog readings. Will be a interesting experiment.
This is where the current sensor propagation delay come into play.
Ahh… The divider. It was at DIV4…
NOW - THIS - tcc->CTRLA.reg |= TCC_CTRLA_ENABLE | TCC_CTRLA_PRESCALER_DIV2;
DIV2
Hmm… Clocking to 180Mhz and Setting the pwm resolution to 2000 gives a 22khz freq. And the hissing from the PSU has seemed to stop, driving the LED´s at decent intensity. There is no heat on the bridges.
I can feel the heat from the LED´s. They are to bright to look at.
For the moment passive cooling is sufficient.
That’s what I’m working on right now, based on the work @malem has done…
What confuses me is that the PWM resolution should have no effect on the iteration speed. But if you’re overclocking, that makes sense.
Using the GCLK_GENCTRL_SRC_DPLL0 is also part of the plan, not as the main clock source but for the PWM… that will give us considerably more resolution or higher possible PWM frequencies…
Awesome…
The pwm freq (period) defines how many counts the TIMER COUNTER makes each iteration and the clock at what speed. It is only logic. Using single slope, the iteration speed can be increased further.
Yes but the PWM frequency / timer counting is quite independent of the FOC loop. At least it should be. And it looks like your code was counting loop iterations. So that’s interesting. Maybe there is a SYNC somewhere that is locking the loop iterations to the PWM. If so that would be bad. I think the code should be using the double buffered registers to prevent exactly that kind of thing.
It should be up/down double sloped PWM. This is important to keep the phases in sync for current sensing, and means the signals stay nice when changing the speed.
No, what im saying is, one loop iteration cant be faster then the time it takes to set the PWM output pin. This is dependent on the period, how many count it takes to reach the TOP and ZERO in dual slope mode.
But 22Khz is decent, right ?
Yes, I think your thinking is correct! If the PWM frequency is X, it doesn’t make sense to set values more often than X. Otherwise you’re setting different PWM levels within the same PWM output period, and this doesn’t really make sense.
On the other hand, due to the double buffered registers it also should not matter, since the new value will be loaded by the timer in the right moment, and values that get set superfluously in between just get ignored.
Note that on most setups and most MCUs people don’t have the luxury of this problem - more the opposite, getting the FOC iterations fast enough :smiley:
22Khz FOC iteration speed is very good!
22Khz LED dimming PWM freq.
