My installation of SimpleFOCStudio is having problems. Some functions work, others do not. Right now it is not receiving telemetry from the ESP32. This set of data repeats and does not change. The “Pull parameters” does work.
It could be my code too. That last field I believe is the data from the AS5600 sensor. It seems quite random upon reset of the ESP32 but once the data stream starts, the values never change. It USED to work and the “Angle” display would track the motor sensor but I have been unable to get it to work again.
Here is the current code:
* ESP32 position motion control example with magnetic sensor
// Motor instance
// define BLDC driver
BLDCDriver3PWM driver = BLDCDriver3PWM(16,17,18,19);
// angle set point variable
// float target_angle = 0;
Wire.setClock(400000);
driver.voltage_power_supply = 14.8;
//motor.voltage_limit = 4;
// angle P controller
//motor.P_angle.P = 20;
//motor.velocity_limit = 20;
// The letter (here 'M') you will provide to the SimpleFOCStudio
command.add('M',doMotor,"motor");
// align sensor and start FOC
// all looks good 24 dec at 11 am...loaded onto board
