Hello everyone! I want to use the position control mode of simpFOC to control a three-axis gimbal. The data return period of the IMU I use is 5 ms, so I send simpleFOC a target position command every 5 ms. But now I find that when I send the same position command every 5ms, the motor shakes at a very low frequency(about 0.5HZ). I tried to change the PID, but it didn’t work. So I want to know whether simpleFOC can complete the control task within 5 ms?
Thanks!
Besides, this is my code:
#define Motor_No 'P'
#define volt_limit 8.0000
BLDCDriver3PWM driver = BLDCDriver3PWM(3, 5, 6, 8);
float target_angle = 0;
float received_angle = 0;
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 3;
motor.P_angle.P = 3;
motor.voltage_limit = 8;
motor.velocity_limit = 20;
motor.LPF_velocity.Tf = 0.01;
motor.move(target_angle);
serialReceiveUserCommand();
static String received_chars;
while (Serial.available()) {
if (inChar == Motor_No)
while (1)
if (inChar == ',')break;
received_chars += inChar;
received_angle = received_chars.toFloat();
target_angle = received_angle;
received_chars = "";
break;
You don’t mention which MCU you use? How quickly the main loop will run will depend on your MCU speed. On a Arduino Nano it might be around 1ms. On a ESP32 it will be considerably faster.
5ms is 200Hz, that’s an ok control speed I would have said - fast enough for pretty dynamic control, but not so fast as to overload the MCU. But there are people here who know much more about such things and may have a better opinion for you.
Do you notice a behaviour difference if you slow down the control messages to 50ms, or 500ms? Really, if you are sending the same position, it should not make a difference how often you send it.
My assumption would be that you have some other problem .e.g. maybe the AS5600 (it is not a very exact sensor) is not that stable… I assume the IMU is not in the control loop in the test you are doing?
I would also code the Serial loop differently - if you do it in the way you posted then you run the risk of reading 1 byte, and then busy-waiting until the next byte arrives. Since serial has no real-time guarantees this could be a potentially long time. I would structure the loop differently, maybe more like this:
char inChar == (char)Serial.read();
if (inChar == ',') {
target_angle = received_chars.toFloat();
else if (inChar != Motor_No)
Probaly the root cause. I have a stupid suggestion perhaps, to debug, comment out the serial calls completely from the loop, and hard-code a full circle with very close positions with 5ms delay and see if it still vibrates.
Hi,runger!
Thanks for your reply! Sorry, I didn’t describe the details clearly.
This is my hardware:
MCU: Atmaga328P, magnetic encoder: AS5600.
My operation is to use the serial port host computer to send the same position to simpleFOC every 5ms, and it will shake.
I tried other control periods, such as 50ms, 500 ms and 1s. The fact is that only when I send a command every 1 second or
more, the motor won’t shake. I also think it is a problem with my serial port, I will try your suggestions later.
Thanks again!
I think it is also a good suggestion and I will try it.
Thanks,Valentine!
Hi,runger!
Amazing! I tried to change the serial port part into your code and it worked! Thank you very much!
Hey, I’m happy! The reason then was the delays caused by the serial communications…
