Hello, I use a teensy and an IFX007T and a hoveboard motor.
But for some time I can no longer make software adjustments,
I can only change / motor.move(); or the switching frequency. But I have no power to my motor, no torque
#include <FlexCAN_T4.h>
FlexCAN_T4<CAN2, RX_SIZE_256, TX_SIZE_16> Can2;
CAN_message_t msg;
int StBy = 2; // Stby CanBus
int ReceptionPwm = 0 ;
float Cible = 0 ;
int SensDeRotation = 0 ;
int freewheel = 0 ;
int freewheelTemp = 0 ;
float Couple = 0;
#define PHASE_UH 6
#define PHASE_VH 7
#define PHASE_WH 8
#define PHASE_UL 3
#define PHASE_VL 4
#define PHASE_WL 5
BLDCMotor motor = BLDCMotor(15, 0.8);
BLDCDriver3PWM driver = BLDCDriver3PWM(PHASE_UH, PHASE_VH, PHASE_WH, PHASE_UL, PHASE_VL, PHASE_WL);
HallSensor sensor = HallSensor(21, 20, 19, 15); //21 20 19
void doA() {
sensor.handleA();
void doB() {
sensor.handleB();
void doC() {
sensor.handleC();
///////bus can fred///////
pinMode(StBy, OUTPUT);
digitalWrite(StBy, LOW);
Can2.begin();
Can2.setBaudRate(500000);
driver.pwm_frequency = 18000;
// aligning voltage
motor.voltage_sensor_align = 12;
motor.foc_modulation = FOCModulationType::SinePWM; // default
//motor.controller = MotionControlType::angle;
//motor.controller = MotionControlType::velocity;
// motor.useMonitoring(Serial);
// align sensor and start FOC
motor.PID_velocity.P = 0.02 ;//0.2
motor.PID_velocity.I = 1;
motor.voltage_limit = 8;
motor.PID_velocity.output_ramp = 3000;//300
//motor.LPF_velocity.Tf = 0.05f;
//command.add('T', doTarget, "target voltage");
motor.enable();
//motor.disable();
motor.move(3); // for test
if ( Can2.read(msg) )
ReceptionPwm = msg.buf[0];
Cible = (float)ReceptionPwm / 20 ;//50 le 06/06/2022
SensDeRotation = msg.buf[1];
freewheel = msg.buf[2];
if (SensDeRotation == 0)//sens de rotation 0 ou 1
motor.move(Cible);
else
motor.move(Cible * (-1));
if (freewheelTemp != freewheel)
freewheelTemp = freewheel;
if (freewheel == 0)
motor.disable();
pinMode(PHASE_UH, INPUT_PULLDOWN);
pinMode(PHASE_UL, INPUT_PULLDOWN);
pinMode(PHASE_VH, INPUT_PULLDOWN);
pinMode(PHASE_VL, INPUT_PULLDOWN);
pinMode(PHASE_WH, INPUT_PULLDOWN);
pinMode(PHASE_WL, INPUT_PULLDOWN);
else
pinMode(PHASE_UH, OUTPUT);
pinMode(PHASE_UL, OUTPUT);
pinMode(PHASE_VH, OUTPUT);
pinMode(PHASE_VL, OUTPUT);
pinMode(PHASE_WH, OUTPUT);
pinMode(PHASE_WL, OUTPUT);
motor.enable();
