I am using the NUCLEO-G474RE with the X-NUCLEO-IHM07M1 motor controller board.
if I start in open loop, can I read the electrical angle etc parameters during that operation and then switch to closed loop, smoothly?
If I have a 12V source, I believe I read that I should limit the Motor voltage limit parameter to 6V for the smoothest sine wave. Is that correct?
For a 12V nominal motor, is it preferable to maximize voltage or current to get to the smoothest run? Aka, should I be thinking 6V / 0.5amps or 3V/1.0 amp if it is a 3W motor. (And does that assumption change between open loop and closed loop?)
Thanks!
(This is for a belt driven Turntable, so smooth operation is paramount. I currently have it running in open loop mode with really good performance, but I continue to like to tweek).
