Need help with L298N driver
So it’s been a while since I have done anything but I made some progress on my motor. I have been able to set up the hall sensors and get them work. so now I have been working on getting the L298N to work but when I run the code it just twitches. The scraped to gather code I have been trying to run is
// Hall sensor instance
// HallSensor(int hallA, int hallB , int cpr, int index)
// - hallA, hallB, hallC - HallSensor A, B and C pins
// - pp - pole pairs
HallSensor sensor = HallSensor(15, 16, 17, 10);
BLDCDriver3PWM driver = BLDCDriver3PWM(21, 22, 23);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
// hardware interrupt enable
// limiting motor movements
motor.voltage_limit = 12; // [V]
motor.velocity_limit = 5; // [rad/s] cca 50rpm
// open loop control config
// init motor hardware
motor.move(4);
Serial.print("\t");
'So I don’t know what I’m doing wrong so any help would be appreciated.
thank you for reading :slightly_smiling_face:
Hey, is it the motor from the pictures here?
https://community.simplefoc.com/t/3d-printed-bldc-out-runner-motor/726
From the pictures it looks to me like it has 9 pole pairs, not 15?
Which MCU are you using, the UNO?
