Stm32g474RE / ir2110 / 10 ohm on the gate, 4.7 ohm (2w) + 4.7nf on rc snubber / irfb4110 100v 180a / 1mr shunt 7w (3 low side sensing) 6 220 uf capscitor bank / (I might forgot to add anything here so don’t hesitate to ask.
Honestly I have to point to point solder on a 25mmx3mm copper busbar because pcb prices are high as hell in my country and they always come ending up messed up or damaged.
I know you guys might be saying “do you even know what your doing” or “you probly tried ai to make this bs” guys, I am just trying and I’ll let the AI code it sadly. I just want to learn things too!
I am worried about nh parasitic stuff I mean I dont want to kill the mcu by killing mosfets, I’ll put the dc bus on top of eachother with a layer of kaptop tape, I’ll solder the components with least amount of distance as possible, I also heard about negative voltage on low side like is that true? Also I am not sure to add a rc filter on the low side shunts to let the mcu read them properly. Soldering shunts on a busbar will be hard too.
Please just try to help me on this instead of trying to drag me down. Thank you.
It's a nucleo board! Of course it has pins and all those jumper wire slots! About opamps I am planing to twist the pairs. Also forgot to mention the khz, 20khz.
– User1
