hello people!
i done my all testing of simple foc code for angle controll mode and velocity control mode on 24V. the hardware i used is esp32 controller and driver ic is IR2184 3PWM. the code working absolutly fine. now i want to change into my code i wanted angle and velocity in single code. i am new to simple foc so anybuddy can guide me, it will be much helpfull .
guide me how to give command velocity and angle in single code as well as how to set two seprate PID in single code of simple foc for angle controll & velocity control.
Its not quite clear what you are asking?
Would you like to control position while limiting velocity? You can use the motor.velocity_limit
for thisā¦
Would you like to switch between angle and velocity control?
You can change the motor.controller
dynamically, but you will have to also manage the set-point at the same time, as it has different meanings in these two modes.
Are you trying to implement motion planning? This is kind of out of scope of SimpleFOC itself, but we have an example of simple trapezoidal limiting in our driver library:
Does any of that help?
thanks for listening me !
but i want to controll motor by single , currently there is, you have to choose mode of controll type nd set PID accordingly choosen controll mode like angle, velocity else torque. my quetion is can i run motor with single code by that code i controll angle parameter as well velocity.
Hey,
Still not sure what you mean, but it sounds like something like the trapezoidal planner is what you wantā¦ where you can set an angle target, but control the maximum velocity and acceleration used?
I want to write code that conroll both parameter angle as well as velocity. currenty there are seprate code - closed loop velocity controll 2ndly angle controll closed loop code. i want to merge this code and by single code i can change velocity as well as get angle. although for that i tried simple foc code full serial command encoder which give target both velocity and angle by single command. that looks quite good.
the code is below
BLDCMotor motor = BLDCMotor(2);
BLDCDriver3PWM driver = BLDCDriver3PWM(25, 26, 27, 32);
// encoder instance
Encoder encoder = Encoder(15, 4, 1024);
// channel A and B callbacks
// commander interface
encoder.init();
motor.linkSensor(&encoder);
// link driver
// choose FOC modulation
// angle PID controller
// default P=20
motor.P_angle.P = 0.21;
motor.P_angle.I = 0.11; // usually only P controller is enough
motor.P_angle.D = 0; // usually only P controller is enough
motor.voltage_limit = 24;
motor.LPF_angle.Tf = 0.1; // default 0
// angle loop controller
motor.P_angle.P = 20;
// angle loop velocity limit
//motor.velocity_limit = 190;
// monitoring port
// initialise motor
motor.target = 1;
// define the motor id
command.add(āMā, onMotor, āmotorā);
Serial.println(F(āMotor commands sketch | Initial motion control > torque/voltage : target 2V.ā));
now i want to add also velocity PID and and its LF constant.
Go ahead and add those settings then
Angle mode also uses the velocity PID, and tuning that one is actually usually more important than the angle PID, where usually a simple P-controller is enough
Yes itās working good in angle mode but there any way to give angle command in degree. Generallly simple foc code give angle in radian/s
No, SimpleFOC works in radians, or rad/s for velocity.
But itās simple to convert the units in your own codeā¦
there is no way we can move motor with degree scale?
No. Just convert degrees to radians.
I tested above code . happily, it works good in angle controll mode. I got angle as my wish, but motorās velocity speed not going to above 50rad/s. There is no effect of increseing veocity , i gave velocity command 2500rad/s, but my motor still moving with speed of 50rad/s. So there is any solution that i can incresed my motorās velocity as angle.
Hmm thatās not even 500RPM - whatās the KV value of your motor?
my motor KV value is 144.
and one another suggestion i needed is i tried this encoder simple foc velocity controll mode with DRIVER 6PWM Ic IR2133S , controller is same ESP32 but it run in open loop but not responding encoder code. I checked encoder pulse with DSO and its fine. so any suggestion how i can operate it with velocity controlll loop. the code i used is given below
#define SIMPLEFOC_PWM_HIGHSIDE_ACTIVE_HIGH true
#define SIMPLEFOC_PWM_LOWSIDE_ACTIVE_HIGH false
BLDCDriver6PWM driver = BLDCDriver6PWM(25, 26, 27, 14, 12, 13, 32);
// encoder instance
Encoder encoder = Encoder(4, 5, 1024);
float target_velocity = 1.5;
// initialize the pushbutton pin as an input:
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
encoder.init();
encoder.enableInterrupts(doA, doB); //, doC);
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.035f;
motor.PID_velocity.I = 0.40;
// align sensor and start FOC
command.add(āTā, doTarget, ātarget voltageā);
Serial.println(F(āMotor ready.ā));
Serial.println(F(āSet the target velocity using serial terminal:ā));
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
// motor.monitor();
If you donāt mind, could you post code using back-ticks so it is easily readable?
You canāt #define SIMPLEFOC_PWM_HIGHSIDE_ACTIVE_HIGH
in your code, you have to define it in the platformio.ini or your board definition files so the compiler applies it to all the code it compilesā¦
hey thanks for listening,
I removed this SIMPLEFOC_PWM_HIGHSIDE_ACTIVE_HIGH from code, make other changes. And now Code working good with 6pwm Encoder on this board too.
