I want to test the continuous rotation speed of the motor. Which example should I use?(velocity)
I have
1.gimbal motor mitoot 2805/140KV
2.SimpleFOC MINI
3.mcu i use stm32f103 bluepill
Which example should I use in the arduino ide?
  • STM32 Bluepill position motion control example with encoder
  • The same example can be ran with any STM32 board - just make sure that put right pin numbers.
// Motor instance
// BLDCDriver3PWM(IN1, IN2, IN3, enable(optional))
BLDCDriver3PWM driver = BLDCDriver3PWM(PB6, PB7, PB8, PB5);
// encoder instance
Encoder encoder = Encoder(PA8, PA9, 8192, PA10);
// channel A and B callbacks
void doI(){encoder.handleIndex();}
// angle set point variable
float target_angle = 100;
float target_velocity = 10;
encoder.init();
encoder.enableInterrupts(doA, doB, doI);
motor.linkSensor(&encoder);
//driver.voltage_limit = 6;
// aligning voltage [V]
motor.voltage_limit = 6;
//motor.controller = MotionControlType::velocity_openloop;
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 20;
//motor.PID_velocity.D = 0;
// angle P controller
// motor.P_angle.P = 2000;
//motor.velocity_limit = 1000;
//command.add(‘T’, doTarget, “target angle”);
//Serial.println(F(“Motor ready.”));
//Serial.println(F(“Set the target angle using serial terminal:”));
// _delay(1000);
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
//motor.loopFOC();
// motor.monitor();
I have the same motor.
You don’t have a sensor, so all you can do is open loop.
None of the examples are exactly right for any situation that will be encountered, you have to adapt them.
The open loop example, ideally if there is one specifically for the bluepill, is the way to go.
Make sure you set the voltage way down, like 1 or 2 volts, also set the power supply.
i solved thank so much
