How to use AS5048A PWM model to do FOC control?
My system is like photo below:
And I try the "getting start " subsection codes of “writing the code” section. I succeed in the Step 1. Testing the sensor, Step 2. Testing the driver + motor combination - open-loop but failed in Step 3. Closed-loop control - torque using voltage with :
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CCW
MOT: PP check: fail - estimated pp: 39.05
MOT: Zero elec. angle: 5.11
MOT: No current sense.
MOT: Ready.
Motor ready.
and my codes like:
#include  <arduino.h>
// motor
// driver
BLDCDriver3PWM driver = BLDCDriver3PWM(9,5,6,8);
// sensor
MagneticSensorPWM sensor = MagneticSensorPWM(2, 12, 4111);
void doPWM(){sensor.handlePWM();}
// Commander command = Commander(Serial);
// void doTarget(char* cmd) { command.scalar(&motor.target, cmd); }
// void doLimit(char* cmd) { command.scalar(&motor.voltage_limit, cmd); }
  sensor.enableInterrupt(doPWM);
  if(!driver.init()){
    return;
  // aligning voltage
  if(!motor.init()){
    return;
  // align sensor and start FOC
  if(!motor.initFOC()){
    Serial.println("FOC init failed!");
    return;
  // set the initial motor target
  motor.target = 2; // Volts
  // add target command M
  command.add('M', doMotor, "Motor");
  Serial.println(F("Set the target using serial terminal and command M:"));
what’s the problem?
Hi @ErDong886 , welcome to SinpleFOC!
I would advise strongly against using the PWM mode of the sensor. The speed and accuracy are very low, and it will greatly limit your performance, if you get it working at all.
This sensor has a SPI interface, that will work much better…
Thanks for your reply!!! I will try it soon.
