How to Modify "motor.voltage_limit" in the loop() in "MotionControlType::angle" mode
I try to modify the “motor.voltage_limit” value in the main loop via a serial command but the new value is not applied. I need to call motor.init() for it to be applied but it stop the motor while doing this.
Thanks,
Here is the code :
TwoWire I2COne = TwoWire(0);
BLDCDriver3PWM driver = BLDCDriver3PWM(32, 33, 25, 22);
float target_angle = 0;
void doP(char* cmd) { command.scalar(&motor.PID_velocity.P, cmd); }
void doI(char* cmd) { command.scalar(&motor.PID_velocity.I, cmd); }
void doV(char* cmd) { command.scalar(&motor.voltage_limit, cmd); motor.init(); }
  I2COne.begin(19, 18, 400000);
  sensor.init(&I2COne);
  driver.voltage_limit = 3;
  //motor.controller = MotionControlType::torque;
  motor.PID_velocity.P = 0.05f;
  motor.PID_velocity.I = 2;
  motor.voltage_limit = 1;
  motor.P_angle.P = 20;
  motor.velocity_limit = 40;
  command.add('t', doTarget, " target_angle");
  command.add('p', doP, " motor.PID_velocity.P");
  command.add('i', doI, " motor.PID_velocity.I");
  command.add('v', doV, " motor.voltage_limit");
  motor.move(target_angle);
  // motor.monitor();
Yes, it’s very confusing. You need to set motor.PID_velocity.limit. During initialization it’s set to either voltage_limit or current_limit depending on whether you provide a method of current limiting (a current sensor or kv and resistance for voltage-based current limiting), so afterward you have to change it directly.
Thanks dekutree64, that worked perfectly :slight_smile:
