GM3506 listing gives torque at 12 V and 1 A but no continuous current. How do you check a gimbal motor before buying?
I was looking at the iFlight iPower GM3506 gimbal motor with the AS5048A encoder. The listing gives 600 to 1000 g·cm of torque, but only as a test at 12 V and 1 A, and it never says how much current the motor can take continuously. The only voltage it gives is “2-3S”, and that sits on a line labelled working current. So I can’t tell from the listing how hard I can drive it.
Am I the only one who only caught this on a second read? How do you guys check a gimbal motor before you buy it?
The weight is 64 grams, and 1Nm/kg continuous, 2x peak is typical for small motors, so that seems right. Voltage ratings are only a suggestion. The only practical limits are winding insulation breakdown and mechanical explosion, and you’re unlikely to reach either of them on a low kv motor like this. 12V is probably chosen to be safe at zero speed (around 2 amps by the listed resistance) for control without current sense.
As @dekutree64 said, the true limits are hard to predict. It mainly depends on motor temperature and external cooling.
I wouldn’t look for the copper wire insulation breakdown temperature, because the magnet depolarisation temperature is probably lower.
