Hello!
I finally have gotten my Storm32 V1.32 board working with my setup and have moved on to the code. To give some details about my setup I am using a iPower GM3506 motor and a AS5048A magnetic encoder (3 wire set up). The code below is what I tried piecing together (first time doing this):
//Motor 0 Pins
const int MOT0_PhA = PB1;
const int MOT0_PhB = PB0;
const int MOT0_PhC = PB7;
//Encoder Pins PWM
const int ENC1 = PC0;
const int ENC2 = PC1;
const int ENABLE_PIN = PA4;
//Poles of motor
const int pole_pair = 11;
float target = 1.0;
// Setting up sensors
MagneticSensorPWM sensor = MagneticSensorPWM(PC0, 5, 935);
void doPWM(){sensor.handlePWM();};
// Motor init
BLDCMotor motor = BLDCMotor(pole_pair);
BLDCDriver3PWM driver = BLDCDriver3PWM(MOT0_PhA, MOT0_PhB, MOT0_PhC, ENABLE_PIN);
void serialLoop() {
static String received_chars;
while (Serial.available()) {
char inChar = (char) Serial.read();
received_chars += inChar;
if (inChar == '\n') {
target = received_chars.toFloat();
Serial.print("Target = ");
Serial.println(target);
received_chars = "";
// comment out to use sensor in blocking (non-interrupt) way
sensor.enableInterrupt(doPWM);
// limiting motor movements
motor.voltage_limit = 4; // [V]
motor.velocity_limit = 12; // [rad/s] cca 50rpm
// open loop control config
// init motor hardware
motor.move(target);
Serial.print("\t");
The issue I am having is the motor powers on and begins oscillating a very small amount (ex: going form 0 degrees to 3 back to 0). Not really sure where to begin to troubleshoot but any help would be greatly appreciated!
