Esp32 ignores the search for the encoder index
BLDCDriver3PWM driver = BLDCDriver3PWM(25, 26, 27, 7);
// encoder instance
Encoder encoder = Encoder(4, 2, 600, 33);
// channel A and B callbacks
void doI(){encoder.handleIndex();}
// angle set point variable
float target_angle = 0;
  encoder.init();
    encoder.enableInterrupts(doA, doB, doI);
  motor.linkSensor(&encoder);
  // aligning voltage [V]
hello. does esp32 support the encoder index?
Hi @nikolaewich1988,
For the Encoder class, the implementation is based on interrupts, and it doesn’t matter which MCU you use. If the encoder has an index pin, and you configure it correctly, it should work on any MCU.
Which ESP32 are you using? Does it work if you use a different pin than GPIO33?
sorry to disturb There was an error in connection on my part ((((
