Will this encoder work well with SimpleFOCShield 2.0.4?
I am looking for a thruhole encoder that can support a 5mm, 1/4", and 8mm shaft for different BLDC motors I want to compare in closed loop speed control. Speed monitored from 33 - 300 RPM. I would like to get very precise control of the speed, as the intent is to get a constant speed for a turntable project (comparing direct drive vs belt drive).
Thanks for the help.
