DRV8302 + Arduino Uno issue
Hello, I’m trying to run velocity_openloop, just to test my DRV8302 board.
I use the following snippet:
// DRV8302 pins connections
// don't forget to connect the common ground pin
#define INH_A 9
#define INH_B 10
#define INH_C 11
#define EN_GATE 7
#define M_PWM A1
#define M_OC A2
#define OC_ADJ A3
// Motor instance
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C, EN_GATE);
  Serial.println("Initializing...");
  // DRV8302 specific code
  // M_OC  - enable overcurrent protection
  pinMode(M_OC,OUTPUT);
  digitalWrite(M_OC,LOW);
  // M_PWM  - enable 3pwm mode
  pinMode(M_PWM,OUTPUT);
  digitalWrite(M_PWM,HIGH);
  // OD_ADJ - set the maximum overcurrent limit possible
  pinMode(OC_ADJ,OUTPUT);
  digitalWrite(OC_ADJ,HIGH);
  // choose FOC modulation
  motor.controller = ControlType::velocity_openloop;
  motor.voltage_limit = 12;
//  motor.useMonitoring(Serial);
  // initialise motor
  motor.target = 2;
  Serial.println("Full control example: ");
which I got by removing the code related to the encoder.
My Arduino Uno gets restarted while trying to execute “motor.initFOC();”
I tried with 2 different boards, even not connected to the DRV.
Could you please take a look?
Thanks in advance!
Remove the ‘initFOC ()’ call.
In the library version v2.0.x the initFOC and loopFOC should not be called in open-loop mode. :slight_smile:
This will change in v2.1
Thank you! I nearly burned my motor :slight_smile: But in the end, it worked!
Also, could you give me a hint on pole pairs, if I have a motor saying 12N14P, which parameter should I use?
And also a general question, did you manage to get a smooth movement of an outrunner RC-motor?
Hey @zjor,
Given what the manufacturer says, N means the number of coils and P means the number of poles (magnets). To know the number of pole pairs divide P (poles) by two, in you case 14/2 = 7 pole pairs.
Having a 7 pole pair out-runner spin smoothly at slow speeds is very tricky because of cogging torque.
