Driver.voltage_limit of each phase - question
I got a couple of BTS7960 modules yestreday to play around with simpleFOC and since I had some issues with the boards I played previously with, I investigated a little bit before attaching the motor. I’m running this on an STM32f103c8 BluePill.
I have almost no equipment (I can’t analyze it in more depth), but the multimeter does read a few basic things and can be helpful. What I found out is that 2 of the motor phases are toping the voltage to the value driver.voltage_power_supply regardless of the driver.voltage_limit, and only one phase outputs a voltage that doesn’t exceed the driver.voltage_limit (phase C). I swapped around the phases to see if it’s a controller phase not runnng correctly, but it seems to come from the generated signal by the MCU rather than the driver.
I will get myself a chap logic analyzer, but in the meantime, does anyone have any idea if this can be diagnosed somehow in the code?
This is what I thought would be useful, but I have no clue if those are the expected values (pwmA/B/C look odd to me):
driver.dc_a/b/c values seem coherent (0-0.25 120 degree apart)
driver.pwmA/B/C values are constant, A 201, B 200, C 0
This is the code I’m using
BLDCMotor motor = BLDCMotor(15); // hoverboard 6.5 inch
BLDCDriver3PWM driver = BLDCDriver3PWM(PB1,PB0,PB9, PA6,PB8,PA7);
//target variable
float target_velocity = 0;
  driver.voltage_limit = 3;
  // limiting motor movements
  // currnet = resistance*voltage, so try to be well under 1Amp
  // open loop control config
  // init motor hardware
  target_velocity = 0.5;
I think I got it - I messed up the wiring on the perboard (mixed up the pins).
