Disable Initial Setup Print Messages
Is it possible to disable the initial setup print statements from appearing? (shown below)
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Skip dir calib.
MOT: Skip offset calib.
MOT: No current sense.
MOT: Ready.
Thank you for your help.
Are you using arduino ide or platform ide? What CPU is this?
Hi @Luca, Iā€™m using serial monitor on Arduino 1.8.16 for Arduino Uno
@bwm those messages are DEBUG messages. ie:
SIMPLEFOC_DEBUG("MOT: Monitor enabled!");
You can find more info on how to manage debug messages here Debugging | Arduino-FOC
This text is printed by the Moore monitoring. The simplest way to disable them is not to use motor monitoring.
Just comment out motor.useMonitoring(&Serial);.
Here are the monitoring docs: ahttps://docs.simplefoc.com/monitoring
If you need the motor monitor to be output the motor variables, but do not want these monitoring messages at startup, then just put the line motor.useMonitoring(&Serial); after motor.initFOC();
Thank you very much @Aleksandar_Markovic and @Antun_Skuric, that is very helpful.
