Current Sensing basic question
Hi all,
I’m planning to drive a Nema 17 with an AS6600 and an ESP32 as MCU. But when it comes to current sensing, I’m a bit lost. Until now I only used BLDC with the Shield 3.1, making things quite easy… but that’s not applicable in this case.
In the Docs I’ve read the according pages. Unfortunately I’m prone to thinking way to complicated or thinking things are complicated and get stuck in a mental loop or simply error out… looking at the picture
I see the two resistors between the driver(s) and the motor, but what’s happening next? INA240 (or comparable) and then output to MCU ADC pins?
2
The blue and red triangles represent the current sense amplifiers (like INA240) and the i_a/i_b are implied to be the (digital or analog) current measurement signals going to the controller. Otherwise you seem to have the right idea.
This diagram is drawn in a sort of unconventional way with the drivers on either side and the motor in the middle. The stepper motor should be shown with two phase inductors/resistors inside, one connected across the blue wires and a different one connected across the red wires.
ah, superb, many thanks!
