Hello i have a SimpleFOC programm and i want to send the command froma a Computer to the Esp32 it works fine but when i want to send the Command M10.52 50 2.1. So 10.52 rad, 50 rad/sec and 2.1 Tourque the motor just doesn’t move at all.
Here is the code i use.
* Position/angle motion control example
* Steps:
* 1) Configure the motor and magnetic sensor
* 2) Run the code
* 3) Set the target angle (in radians) from serial terminal
#include <Wire.h>
#define I2C_SDA 21
#define I2C_SCL 45
MotionControlType prev_controller;
float prev_voltage_limit;
float prev_velocity_limit;
float desired_angle = -11.80903703704;
//MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
InlineCurrentSense current_sense = InlineCurrentSense(0.004f, 20.0f, 6, 7);
BLDCMotor motor = BLDCMotor(15, 0.502, 18.1, 0.0007758);
BLDCDriver3PWM driver = BLDCDriver3PWM(48, 47, 46);
void Cali_Start(char* cmd) {
prev_controller = motor.controller;
prev_voltage_limit = motor.voltage_limit;
prev_velocity_limit = motor.velocity_limit;
// Limits setzen
motor.voltage_limit = 12; // max Torque
motor.velocity_limit = 2.0; // max Speed
// Ziel setzen
motor.move(-2.8);
void Cali_End(char* cmd) {
motor.sensor_offset = motor.shaft_angle - desired_angle;
motor.controller = prev_controller;
motor.voltage_limit = prev_voltage_limit;
motor.velocity_limit = prev_velocity_limit;
motor.target = desired_angle;
Wire.setClock(400000);
Wire.begin(I2C_SDA, I2C_SCL);
sensor.init(&Wire);
driver.pwm_frequency = 20000;
if(!driver.init()){
return;
if(!current_sense.init()){
Serial.println("Current sense init failed!");
return;
// contoller configuration
motor.current_limit = 200;
motor.velocity_limit = 200;
motor.PID_velocity.P = 3.0;
motor.PID_velocity.I = 1.0;
motor.PID_velocity.D = 0.002;
motor.LPF_velocity.Tf = 0.05;
motor.PID_velocity.limit = motor.velocity_limit;
motor.P_angle.limit = 200.0;
motor.P_angle.P = 2.0;
motor.P_angle.I = 0.025;
motor.P_angle.D = 0;
motor.LPF_angle.Tf = 0.05;
motor.PID_current_d.limit = motor.current_limit;
motor.PID_current_q.limit = motor.current_limit;
if(!motor.init()){
return;
// align sensor and start FOC
if(!motor.initFOC()){
Serial.println("FOC init failed!");
return;
// add target command M
command.add('M', doMotor, "Motor");
command.add('CS', Cali_Start, "Calibration_Start");
command.add('CE', Cali_End, "Calibration_End");
motor.monitor_downsample = 1000; // disable monitor at first - optional
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
//motor.monitor();
