I am trying to run a BLDC motor using esp32s. I tried using the example program “find pole pairs number” in the code I have modified lines
BLDCDriver6PWM driver = BLDCDriver6PWM(12, 14, 27, 26, 25, 33);
HallSensor sensor = HallSensor(32, 35, 34, 1);
driver.pwm_frequency = 25000;
driver.voltage_power_supply = 11;
driver.dead_zone = 0.20f; //4us dead time
Other than the above lines the program is same. In serial terminal I get pp= 1080.00/ -5672519.50 i.e pp=-0.00 and since pole pair number cannot be negative try changing search_voltage/ sensor configuration. Should the voltage_power_supply value given driver supply voltage or supply voltage given to the motor and should the pp_search_voltage given half the voltage_power_supply. Moreover I have also tried interchanging hall sensor cables but the same result occurs. I have also uploaded code for your reference. Kindly help
void serialReceiveUserCommand();
float target_voltage = 2;
static String received_chars;
while (Serial.available()) {
// get the new byte:
received_chars += inChar;
// end of user input
if (inChar == '\n') {
// change the motor target
target_voltage = received_chars.toFloat();
Serial.print("Target voltage: ");
Serial.println(target_voltage);
// reset the command buffer
received_chars = "";
// BLDC motor instance
// its important to put pole pairs number as 1!!!
// BLDCDriver3PWM driver = BLDCDriver3PWM(9, 5, 6, 8);
//esp32 pins
// Stepper motor instance
//StepperMotor motor = StepperMotor(1);
// MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
// magnetic sensor instance - I2C
//MagneticSensorI2C sensor = MagneticSensorI2C(0x36, 12, 0X0C, 4);
//digital hall sensors
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
// sensor.pullup = Pullup::USE_EXTERN;
// hardware interrupt enable
// power supply voltage
// default 12V
driver.dead_zone = 0.20f; //0.10==2us //max is 0.04 for 25k Hz which gives 8us
// initialize motor hardware
// monitoring port
// pole pairs calculation routine
Serial.println(“Pole pairs (PP) estimator”);
Serial.println("-\n");
// float pp_search_voltage = 4; // maximum power_supply_voltage/2
float pp_search_voltage = 6; // maximum power_supply_voltage/2
float pp_search_angle = 6*_PI; // search electrical angle to turn
// move motor to the electrical angle 0
motor.voltage_limit=pp_search_voltage;
motor.move(0);
// read the sensor angle
sensor.update();
float angle_begin = sensor.getAngle();
_delay(50);
// move the motor slowly to the electrical angle pp_search_angle
float motor_angle = 0;
while(motor_angle <= pp_search_angle){
motor_angle += 0.01f;
sensor.update(); // keep track of the overflow
motor.move(motor_angle);
_delay(1);
// read the sensor value for 180
sensor.update();
float angle_end = sensor.getAngle();
_delay(50);
// turn off the motor
motor.move(0);
// calculate the pole pair number
int pp = round((pp_search_angle)/(angle_end-angle_begin));
Serial.print(F("Estimated PP : "));
Serial.println(pp);
Serial.println(F("PP = Electrical angle / Encoder angle "));
Serial.print(pp_search_angle*180/_PI);
Serial.print(F("/"));
Serial.print((angle_end-angle_begin)*180/_PI);
Serial.print(F(" = "));
Serial.println((pp_search_angle)/(angle_end-angle_begin));
Serial.println();
// a bit of monitoring the result
if(pp <= 0 ){
Serial.println(F("PP number cannot be negative"));
Serial.println(F(" - Try changing the search_voltage value or motor/sensor configuration."));
return;
}else if(pp > 30){
Serial.println(F("PP number very high, possible error."));
}else{
Serial.println(F("If PP is estimated well your motor should turn now!"));
Serial.println(F(" - If it is not moving try to relaunch the program!"));
Serial.println(F(" - You can also try to adjust the target voltage using serial terminal!"));
// set the pole pair number to the motor
motor.pole_pairs = pp;
//align sensor and start FOC
Serial.println(F("\n Motor ready."));
Serial.println(F(“Set the target voltage using serial terminal:”));
// uq voltage
// float target_voltage = 2;
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_voltage);
// communicate with the user
