CAN vs USB: A few questions
Hi, I’m trying to figure out if using CAN makes any sense.
The microspora board has two CAN connectors to daisy-chain several boards.
The CANcommander transceives data from an USB to CAN adapterboard.
  • What about the Webcommander? Can I select, which CAN address(es) to read?
  • Is it possible to read more than one microspora board from the same USB adapter?
  • In the example code the CAN adress is 15. Is that the highest number? (0-15)
What else are the benefits of CAN? Max. wiring length?
Thanks for reading
PS: How much cheaper would a microspora board be without CAN?
So CAN bus has a few features which makes it fit well for motor control applications.
  1. It can have multiple devices on one bus. Address length is 11 bits by default but you won’t get anywhere near 2048 devices on one bus due to wiring limits being hit way earlier than addressing limits. The large number of addresses is useful for hardware filtering of different datastreams, for use cases where some data might have different priority than others, multicast, etc.
    For protocol efficiency reasons, especially when using CAN FD, 29 bit addresses should be avoided. Because in CAN FD the data phase is many times faster (common rates are 2mbps-8mbps) than the arbitration phase (common rates are 250kbps-1mbps) where the address is sent.
  2. CAN bus can go a very long distance as it’s a differential protocol. Personally I’ve managed to get it working at 10mbps data 1mbps arbitration over 40m of a 2 core section cut from a roll of jumper wire ribbon cable. Though proper wiring with short stubs and correct termination is required if you want long distance, for short distances you can get away with crappy wiring.
  3. CAN bus has checksum built in, so corrupt packets (due to EMI, cable unplugged, etc) are basically a non issue.
CAN FD SIC transcievers can be had for around $2 and the CAN controller is built into many STM32s (including the STM32G4 used on Microspora). So the cost saving from removing CAN is quite small. More basic CAN transcievers can be obtained for $0.5 if you really want to get it for cheap.
Depending on the UI it might limit you to only controlling one motor at a time however that’s more a UI limitation not a USB to CAN adapter limitation or a hardware limitation.
