Hello! I have an issue while trying to run a GM3506 motor with a as5048A hall sensor.
While running open loop velocity control the motor just twitches back and forth (see video: Google Drive: Sign-in)
Here in an image of the general setup aswell
(Google Drive: Sign-in)
The power supply is 12V, max 6A
The soldered pins on the back for (pwmA, pwmB, pwmC, enable) is (5, 9, 6, 8)
The hall sensor works and gives valid readings.
Heres the code:
BLDCDriver3PWM driver = BLDCDriver3PWM(5, 9, 6, 8);
//target variable
float target_velocity = 3;
// limiting motor movements
motor.velocity_limit = 5; // [rad/s] cca 50rpm
// open loop control config
// init motor hardware
