Arduino no output
Hi.
I’m trying to make an arduino setup with ir2110 and igbt or mosfet as final to drive a 3 phase compressor inverter.
i tryed this program but i dont have any output:
#define INH_A 3
#define INH_B 5
#define INH_C 9
#define INL_A 11
#define INL_B 6
#define INL_C 10
#define EN_GATE 7
BLDCDriver6PWM driver = BLDCDriver6PWM(INH_A,INH_A, INH_B,INH_B, INH_C,INL_C, EN_GATE);
//target variable
int target_velocity = 1000;
  driver.voltage_limit = 15;
  driver.pwm_frequency = 20000;
  // limiting motor movements
  // open loop control config
I really dont know what it wrong with the setup.
A few things to change:
BLDCDriver6PWM(INH_A,INL_A, INH_B,INL_B, INH_C,INL_C, EN_GATE);
→ remove this from the main loop - you won’t get proper motion if you have such long delays in the loop.
→ add it after the motor.controller = MotionControlType::velocity_openloop; line
Please take a look at our examples directory in the library (available from the Examples Menu in ArduinoIDE), there are many examples for the different modes and different setups.
The order of doing things in the setup is important, so it is good to have examples.
//BLDCDriver3PWM driver = BLDCDriver3PWM(9, 5, 6, 8);
// BLDCDriver6PWM(IN1_H, IN1_L, IN2_H, IN2_L, IN3_H, IN3_L, enable(optional))
BLDCDriver6PWM driver = BLDCDriver6PWM(PA8, PB13, PA9, PB14, PA10, PB15, PB12);
//target variable
float target_velocity = 100;
  driver.voltage_limit = 6;
  driver.pwm_frequency = 2000;
  // init motor hardware
  //_delay(1000);
I understand from the wiki that arduino uno has pwm frecvency limitation at 32khz or 4 khz .
I need it to be adjustable so that i have the right settings for the motor.
The above code is for stm32 bluepill board clocked at 2 khz but according to my osciloscop the frecvency does not change it remains at 25khz.
I measured with nothing attached.
Thanks
Hi @Vlad_Daniel,
Sounds like you’re making progress :slight_smile:
Please set the frequency before calling driver.init() and see if this helps.
yes it change now.I will connect the setup and power it up to see if all is working ok.
by the way is ir2104 better than ir2110?
I’m getting no output from the ir2110.
The below picture is rough sketch of the schematic with stm32 and ir2110
the motor does not start
