I need some help here.
I have a Technics direct drive PMSM that I’m driving with an STM32F4. In openloop it runs tolerably well, but speed stability is still well off the 1970’s analog PLL.
This is the openloop code and it starts the motor and I’m able to send T and L commands to the STM32 via the USB
BLDCMotor motor = BLDCMotor(10, 27);
BLDCDriver3PWM driver = BLDCDriver3PWM(PA7, PA6, PA5, PA3); // STM32
//target variable
float target_velocity = 0;
float target = 0.0f;
LowPassFilter targetFilter = LowPassFilter(5.4f); // 1s time constant
driver.voltage_limit = 6.0;
// limiting motor movements
motor.current_limit = 0.5; // [Amps]
// open loop control config
// init motor hardware
Serial.println("Set voltage limit");
// command (T 3.4903) 33.33rpm = 3.48rad/s on test SP10
motor.move(targetFilter(target_velocity));
My issue is if the platter is disturbed it takes more than 30seconds for it to stabilize again. I’m looking to close the loop and add a PID.
My first issue the sensorless code will not send serial commands to the STM32 like the previous code does via the USB.
// Sensorless FOC for STM32
#include <SimpleFOCDrivers.h>
#include "encoders/MXLEMMING_observer/MXLEMMINGObserverSensor.h"
// Stepper motor & BLDC driver instance
// MXLEMMING observer sensor instance
MXLEMMINGObserverSensor observer = MXLEMMINGObserverSensor(motor);
// ACS712-05B has the resolution of 0.185mV per Amp
LowsideCurrentSense current_sense = LowsideCurrentSense(185.0f, PA1, PA2);
void doMotor(char* cmd){ command.motor(&motor, cmd); }
motor.linkSensor(&observer);
// link driver
current_sense.init();
// initialise motor
// skip the sensor alignment
motor.sensor_direction= Direction::CW;
motor.zero_electric_angle = 0;
// motor monitoring
