About 6 PWM drive board
I use fd228t to make a drive board, and use esp32’s 6 PWM to drive the motor. In the open loop, the speed and position are normal, but in the closed loop, both the position and the speed do not turn. In doubt, please have a look! thank you!
Open loop code:
//BLDCMotor motor = BLDCMotor(11);
//BLDCDriver3PWM driver = BLDCDriver3PWM(9, 5, 6, 8);
BLDCDriver6PWM driver = BLDCDriver6PWM(25, 12, 26, 13, 27, 14);
//target variable
float target_velocity = 0;
 //   driver.pwm_frequency = 50000;
 //  driver.dead_zone = 0.05;
  driver.voltage_power_supply = 8;
  // limiting motor movements
  motor.voltage_limit = 1;   // [V]
  motor.velocity_limit =20; // [rad/s] cca 50rpm
  // open loop control config
  // init motor hardware
Closed loop code:
// encoder instance
Encoder encoder = Encoder(5, 18, 4096);
//Encoder encoder = Encoder(5, 18, 4096, A0);
// channel A and B callbacks
void doA() {
  encoder.handleA();
void doB() {
  encoder.handleB();
  encoder.init();
  // software interrupts
  motor.linkSensor(&encoder);
  driver.pwm_frequency = 40000;
  driver.dead_zone = 0.04;
  // aligning voltage [V]
  // contoller configuration
  motor.PID_velocity.P = 0.15;
  motor.PID_velocity.I = 10;
  motor.LPF_velocity.Tf = 0.01;
  // align sensor and start FOC
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  // motor.monitor();
Hey @feng,
we need a bit more info.
Did you test your encode?
Is the pole pairs number corrcet?
What does it mean that it is not normal?
Can you provide the monitor output of the initFOC so we can see if the align went well?
Hi@Antun_ Skuric
This is the schematic:
The motor is: https://www.bauer-modelle.com/epages/Bauer_ Uwe46269592.mobile/de_ DE/?ObjectPath=/Shops/Bauer_ Uwe46269592/Products/4.353635&ViewAction=ViewProduct
In the process of operation, electrode check error:
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_ direction==CCW
MOT: PP check: fail - estimated pp:26.6840
MOT: Zero elec. angle: 4.74
MOT: No current sense.
MOT: Ready.
Motor ready.
Later, I directly annotated the library file check electrode detection:
“BLDCMotor.cpp”
// check pole pair number
if(monitor_port) monitor_port->print(F("MOT: PP check: "));
float moved = fabs(mid_angle - end_angle);
if( fabs(moved*pole_pairs - _2PI) > 0.5 ) { // 0.5 is arbitrary number it can be lower or higher!
if(monitor_port) monitor_port->print(F(“fail - estimated pp:”));
if(monitor_port) monitor_port->println(_2PI/moved,4);
}else if(monitor_port) monitor_port->println(F(“OK!”));
}else if(monitor_port) monitor_port->println(F(“MOT: Skip dir calib.”));
But the result is the same.
All the process is like this, I don’t know where to go wrong?Please help to solve it! Thank you!
