6pwm driver stuck at 4khz (noisy)
hi!
i have an esp32 connected to a 6pwm driver with a as5600 encoder via i2c.
if i run the closed loop sketches there is a distinct 4khz (250us cycle) whine coming from the motor.
trying to change the driver.pwm_frequency has no impact as far as i can tell.
how can i go about fixing this?
the issue is consistent across multiple esp32 boards.
if i run 2 motors closed loop with 1 esp32 the 4khz whine remains rock steady.
(if i ground or touch random solder joints it sometimes changes to a 2.66khz (375us cycle) so thats also strange)
i got the same result with a battery as power-supply.
i think the board itself works because in openloop the driver works nicely with 20khz and up.
i hope this is solvable and not a flaw of the setup that i’m using.
here’s the code:
BLDCDriver6PWM driver = BLDCDriver6PWM(14, 27, 26, 25, 33, 32);
float target_velocity = 6.2;
 Wire.setClock(400000);
 driver.pwm_frequency = 100000;
 motor.PID_velocity.P = 0.2;
 motor.PID_velocity.I = 8;
 motor.voltage_limit = 6;
 motor.LPF_velocity.Tf = 0.01;
i just found that my library’s and board’s were not up to date(after spending multiple days on this issue). now i feel stupid but im having a lot of fun so i would still want to thank the makers and all participants of this cool library! i am enjoying it a lot.
Hey @Berend ,
I am not sure that I know what is the issue :smiley:
Which library version were you using?
Can you give us a hint what did you have to change?
hi Antun!
i do not know exactly which versions i previously had. but i think approx. 1 year old
it just worked so never had a reason to update until now.
but i reinstalled/updated the simpleFOC library to v2.2.0
and the esp32 boards to v1.0.6
after updating one of these i tested it, and there were issues with a sync and a mcpwm file, they maybe are related to this problem.
hope this helps!
