I am confused about clarke transform, since each document is using different formula, the switching pattern is
and the projection into alpha, beta as per formula is
Here the factor is 2/3.
In one of the other TI document it is mentioned as
The factor is now Sqrt(2/3). Why is this difference?
The other question is
For the case of A =1, B=0, C=0, the UAlpha = 2Udcbus/3; UBeta = 0, but if i see the space vector diagram
Here it is now 2/sqrt(3), why? If i see other document
with the factor Sqrt(2/3) the space vector is differing. Which one to follow? Lot of confusions. Can someone please help me.
